Guys,
I post this in the hope that someone can give me some advice on what could be wrong with my updated system, full kit at the bottom of the post.
Last week I got myself some new kit, ASUS P5Q Mobo, E8400 CPU and 4GB's of OCZ 8500 Platinum RAM.
After sticking it all together I had a problem installing Win XP, after using a backed up copy of my Installation disk everything was fine, had a good time over the weekend setting everything up and testing the system with the Crysis demo.
This morning I logged on and everything was fine, checked the web, updated my spreadsheets, etc...
I got home this evening only to find that the system wouldn't boot, it got as far as the Windows loading screen and reset, tried restoring from a restore point - same thing happened, tried booting in safe mode - loaded quite a lot of the system but again it reset itself, tried restoring from the disk - again reset as the system loads.
I was able to boot using the Express Gate software.
I then tried a reinstall, everything went fine, as it loaded the Windows setup screen after the install it suddenly reset itself.
I have tried installing on each of my SATA drives and the same thing happens, installs fine but when the system starts to load the setup it resets itself.
I have tried booting the SATA HD's from each of the SATA ports and the same thing happens.
Another oddity is since I installed Windows on one of the drives the system isn't happy booting from the CD with that HD attached any more, it complains about selecting a valid boot drive or bootable disk, but if I change the SATA drive then it is fine.
WTF IS GOING ON?
6+ Years IT Experience, Building and Rebuilding several PC's, a Degree in IT and studying for an MSc in Computer Science....and I have no idea how to sort it out.
I reckon it could be the SATA controller on the Mobo, but why would the Express Gate boot?, or the HD's are dead, possible they are quite old - but all three going at the same time, unlikley.
Any advice is greatly appreciated.
Cheers
Stedders
Kit List:
WTF IS GOING ON?
Cheers
Stedders
Kit List:
- Tagan 1000W PSU
- Akasa Eclipse case
- Asus P5Q Mobo
- E8400 CPU
- OCZ 4GB (2x2GB) 8500 Platinum RAM
- 3 x SATA HD's (One, the old main drive is a WD Raptor 36GB)
- 1 x IDE HD
- 1 x IDE CD/DVD Combi RW
- 1 x Nvidia Geforce 6600GT
