big problems
21 Oct 2011
i have just done a new build and everything seemed ok but then i got a bsod and havin checked it was with the ram, ran the windows 7 check and right enough it told me i had a problem, to narrow it down i tested each of the 2 sticks on there own and no problems found on there own so put them both back in and now i have no input to my monitor, everything else seems to be fine but the memok light is now on :(
asus sabertooth p67
intel i5 2500k
gigabyte gtx 560ti
2x4gb g.skill sniper
ocz 750w psu
do you get any indication on the monitor at all ?
have you run memtest over the memory ?
is the rest of the system powering up ok ?
nothin on my monitor with them in the same colour slots (grey), changed them 2 brown slots and ran the test all went well for a while then bsod :( ran test and a fault again, i have run it with 1 stick at a time and says all is well but when i put the 2 in it will work for a short period then the death :( can no seem to get memtest to work
Does the one stick work in every slot? At this point, I'd agree with Lemin that it's a BIOS settings that's causing the issue. Have you tried loading optimised defaults from the BIOS?
the sticks seem to be ok on there own as it reports no problems but sayin that it said that with 2 at 1 point then the dreaded bsod, i have checked the settings and all seems to be ok, lookin like i will have to send the whole build off to where purchased parts from as all from same place, then they can check the ram and mobo
