Big shout out to AJAX
13 Jan 2004
...without you this PHP application would not be possible.
Took a little bit of reading and messing about to get it going but was all worth it.
In short I am populating fields in a hidden form from 'dead' hyperlinks (href="#") using javascript onClick events after which my ajax function is called and everything fires off to my php processing script...all tidy and transparently in the background.
Totally a tool to put in the back pocket for future projects. :cool:
Now go and provide an accessible JavaScript free version :p. You could probably use noscript tags to display hidden buttons when JavaScript is off to postback your blank hrefs.
I would develop it as accessible if needed. But only me and a few mates will be using the app so no real need.
And not heard of jQuery, I will go have a look.
Never heard of jquery and prototype being linked in any way. Similar sort of thing but would seem odd to have both still in existence if that was the case.
To the OP, I can't believe you havn't heard of jQuery I know quite a few people that wouldnt have a clue about anything but the simplest of javascript but they bang out plenty of stuff using jquery. You are going to love it!
I thought jQuery uses prototype.js for its core.. hence the use of the words "built on".
I understand what you meant by built on, I had just never heard anyone say anything about the two together other than they can be used to accomplish the same sorts of things.
You may be right about it being at the core of jQuery, the selector engine is sizzle I think.
