(Big) Small Form Factor Build Parts Check
14 Aug 2017
Have decided to build a photo/video editing PC in a Cougar QBX (mITX) case - i think I've got half the parts decided, but they need a sanity check and some recommendations to fill gaps. Aiming for max £1200 / $1500.
Basically I was originally hoping for something smaller but it seems that Node 202 and the like, were going to be a pretty tight fit and need some pretty active temperature management and construction handiwork which is a it beyond me. Interested in NCase M1 and Dan A4, but cost and lead time off-putting.
Really grateful for build suggestions on the following:
Motherboard: The one selected is one that was put forward in another thread. I'm not really clear what makes that particular motherboard a good or bad choice. It is described as 'gaming' but gaming won't be a primary feature of the machine - but if it means decent sound and graphics card support great.
Case: Couldn't find the QBX case on PC Part Picker - but I'm going for this: https://www.amazon.com/Cougar-gaming-QBX-Case/dp/B00ZV5YKY6
CPU cooler: Not sure what will fit given the case being small-ish, have noted down Pallas 140mm Low Profile CPU Cooler and Noctua NH-D15 in my research but what would you recommend?
RAM: I want 16GB, but how much does the brand (or speed?) matter?
GPU: I think I want a Geforce 1060 with 6GB memory, but which variant. This seems quite important for the machine, some of the other threads on Reddit talk about having a 'blower' model in the QBX case - likewise heard they can be noisy. Thoughts appreciated, but if the case can include any alternative cooling I might consider it. Don't care about aesthetics, do care about noise/heat. Storage: Will the SSD selected happily work with the motherboard slot?
Power supply: Again, going off another recommendation in a QBX thread in that the SFX PSU with adapter fits well and gives more space inside. Happy for other suggestions though.
Monitor: Lots of photographers have recommended the Dell monitor listed. Again, will consider others but would like something that is a well supported recommendation for my price point.
Keyboard/Mouse: Want wireless variants, but don't need anything super special.
Items Priced So far:
CPU
Intel - Core i7-7700K 4.2GHz Quad-Core Processor £293.00 @ Amazon UK
Motherboard Asus - STRIX B250I GAMING Mini ITX LGA1151 Motherboard £110.35 @ BT Shop
Storage Western Digital - Blue 250GB M.2-2280 Solid State Drive £83.38 @ BT Shop
Storage Western Digital - Red 4TB 3.5" 5400RPM Internal Hard Drive £123.99 @ Aria PC
Power Supply Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply -
Operating System Microsoft - Windows 10 Home OEM 64-bit -
Monitor Dell - U2717D 27.0" 2560x1440 60Hz Monitor £399.98 @ Aria PC
Prices include shipping, taxes, rebates, and discounts
Total £1010.70
I'm not too familiar with ITX builds so all I'll say is that 1440P+GTX1060 is not an ideal combo. Even if it's only a 60Hz 1440P, you are not guaranteed to maintain that @ ultra settings in all games with a 1060. So you'll either have to:
-Reduce the resolution of the monitor, buy a 1080P display
-Get a GTX 1070 instead
-Keep the 1440p/1060 combo but play at medium or high settings, not Ultra.
BTW some G-Sync 24" 1080P monitors are in your price range. You might enjoy the fluidity of gameplay that comes from G-Sync more than you'll enjoy the additional res and a locked 60Hz refresh. JM2C.
At 1080p, the GTX 1060 is a very good choice if you're gaming. If you're going to be photo/video editing though, then you ideally want an IPS monitor as the colours are 'truer'/more accurate. If the 27" 1440p monitor is too much, I can highly recommend this Dell screen:
https://www.overclockers.co.uk/dell...reen-led-monitor-midnight-grey-mo-052-de.html
it's a very good 24" IPS monitor and I've had no issues with mine. I recently upgraded to a Dell S2716DG 1440p G-Sync monitor, but it's a TN panel and the colours are nowhere near as good, even when properly calibrated. So I'm now running a dual-monitor setup with the 27" as my gaming monitor and the 24" Ultrasharp for anything image/video related. At work I also have two of these Dell 24" screens (I'm a CAD engineer by trade) - it's why I bought myself one in the first place.
RAM-wise, I would definitely go with 16GB. Something like this would be my choice, the Team Group if you have the height clearance with the CPU cooler, otherwise the Corsair low-profile:
https://www.overclockers.co.uk/team...nel-kit-black-grey-tdpgd416g30-my-072-tg.html
https://www.overclockers.co.uk/cors...hannel-kit-black-cmk16gx4m2b30-my-445-cs.html
PSU: The Corsair SF600 is one of the best SFX PSUs out there. Review here:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=477
PS, I'd remove the competitor links as it's against the forum rules.
Looks like a nice build, and a that monitor is a pretty good one for photographers yes, but it might be wiser to buy a cheaper but still high quality 24" 1080p monitor now, and save some money for a bigger 4k monitor down the line.
Re: the ssd, the WD blue isn't the fastest thing out there, but it should work just fine in the mobo, and you have 2 slots in case you decide you need another in the future.
