I have an X2 4400+ and have decided to push my CPU a little bit further. As title suggests, its got a Big Typhoon sitting on top of it.
The CPU seems fine when idling - temperatures are 34-37C. After a bit of overclocking, I run the Super Pi 1M test to verify stability. The temperatures would just soar by about 24C bringing it to 55-58C and these X2s apparently have maximum recommended temperatures of 60-65C.
So I'm a little worried that I might damage my CPU, afterall I've only set the max vcore to about 1.5v. Other people have been stating their temperatures don't reach 50c when running these intense benchmarking programs...
I'm begininng to think that it's the Big Typhoon and its inability to dissipate heat quick enough? Though I may be wrong?
My idle temperatures seem fine, so I don't believe the HS needs re-seating. Would mounting a more powerful fan on the BT be a more adequate solution?
I've just checked this thread out:
http://www.digit-life.com/articles2/cpu/heatpipe-massive-shootout-dec2k5-part1.html
and it seems the BT doesn't fair as well as other coolers.
