Bigfoot network card - wireless?
2 Aug 2010
Sussex
Simple question, the new killer xeno pro card by bigfoot seems to have a USB port on the back of it, does this mean I could use my wireless USB adapter to put network traffic through it?
The USB port simply provides storage at the moment AFAIK. This allows you to download torrents etc straight to a flash drive and thus bypassing the Windows networking stack and any CPU overheads needed to write to the HDD.
I dont know if they have updated the ports functionality past this yet.
urg, thats a pain. Can't get a wired connection to where my PC is so have to use wireless and am trying to find ways to improve my connection - was hoping there was finally a way to use a killer network card :(
Sounds like a pointless excercise to me.
If you have a bad wireless connection, plugging it into a NIC isn't going to magically make it better (even if you could do such a thing) - it would still have to go through the wireless adapter with all the inherent problems that brings.
If you genuinely can't use a wired connection and insist on using wireless then there are better ways of trying to improve the situation, such as using improved aerials, wireless repeaters etc.
