Bigger and Better Lian Li Range
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi Guys.
Just thought it would be good to give you all a heads up on the Lian Li range.
I have introduced many new lines over the past couple of weeks.
Lian Li Range
Here are some of the newer products in the range.
Lian Li PC-V750A Midi Tower Case - Silver @ £269.99 inc VAT
With great innovation spawns great products. The Lian Li PC-V750 is moulded from amazing innovatitive ideas hence the "greatness" of this chassis. With a unique front mounting PSU location and base mounted hard drives (along with the usual front HDD cage too) and an amazing ten expansion slots allows the usage of Quad GPU's and room for other cards, like a SATA controller or a dedicated audio card. Your choice of hardware options inside this case surpasses other options on the market.
- Dimensions: (W) 230mm x (H) 440mm x (D) 586mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- Net Weight: 7.35KG
- 5.25" drive bay (External): 1
- 3.5" drive bay (External): None
- HDD bay: 3.5-Inch HDD x9 ( Hotswap x6) / 2.5-Inch HDD x6 ( 2.5-Inch HDD x3 use 3.5-inch)
- Expansion Slots: 10
- Motherboard: E-ATX / XL-ATX / ATX / Micro ATX
- System Fan (Front): 120mm Fan x2
- System Fan (Top): 140mm Fan x2
- System Fan (Rear): 120mm Fan x1
- I/O Ports: USB 3.0 x 2 / USB 2.0 x 1 / e-SATA x1 / HD Audio
- Maximum Compatibility: VGA Card length: 380mm / PSU length: 210mm / CPU cooler height: 170mm
Only £269.99 inc VAT.
ORDER NOW
Lian Li PC-V750B Midi Tower Case - Black @ £269.99 inc VAT
ORDER NOW
Lian Li PC-V750WX Midi Tower Windowed Case - Black @ £299.99 inc VAT
The "X" Edition case includes an all black interior and a side window to show case your system off.
Only £299.99 inc VAT.
ORDER NOW
Lian Li PC-V355A Aluminium Micro ATX Cube Case - Silver @ £94.99 inc VAT
With advancing technology comes better and better Micro ATX motherboard technology. Overclocking features are becoming more rich on the smaller boards. This is where the PC-V355 case shines, allowing you to build an extremely high end PC in such a small footprint. i3, i5 and i7 rigs and long GPU's all with the ability to be overclocked is a breeze in this chassis.
- Dimensions: (W) 283mm x (H) 263mm x (D) 386mm
- HDD bay: 3.5-Inch HDD x3 / 2.5-Inch HDD x1
- Expansion Slots: 4
- Motherboard: Micro-ATX / Mini-ITX
- System Fan (Top): None
- System Fan (Rear): None
- I/O Ports: USB 3.0 x 2 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 210mm / CPU cooler height: 100mm
Only £94.99 inc VAT.
ORDER NOW
Lian Li PC-V355B Aluminium Micro ATX Cube Case - Black @ £94.99 inc VAT
ORDER NOW
Lian Li PC-Q03A Mini-ITX Cube Case - Silver @ £59.99 inc VAT
The ideal of creating the PC-Q03 is to save user's space, the PC-Q03 can fit Mini-ITX mothorboards and ATX power supplies.
PC-Q03 is designed to maximize the natural flow of air through vent holes located on the side and rear panels to cool components.
- Dimensions: (W) 199mm x (H) 245mm x (D) 210mm
- 5.25" drive bay (External): 1( Slim ODD )
- HDD bay: 3.5-Inch HDD x1 (Using 2.5-inch space)/ 2.5-Inch HDD x2
- Expansion Slot: 1
- Motherboard: Mini-ITX /Mini-DTX
- Maximum Compatibility: VGA Card length: 180mm / PSU length: 160mm / CPU cooler height: 60mm
Only £59.99 inc VAT.
ORDER NOW
Lian Li PC-Q03B Mini-ITX Cube Case - Black @ £59.99 inc VAT
- Expansion Slot: 1
ORDER NOW
Lian Li PC-A55A Aluminium Midi Tower Case - Silver @ £79.99 inc VAT
The new PC-A55 is a great Midi Tower case with a great front mounting PSU deisgn to enhance space and airflow. This chassis offers the usual amazing quality that you always expect from Lian Li with it's brilliant brushed aluminium panels.
- Dimensions: (W) 188mm x (H) 375mm x (D) 455mm
- HDD bay: 3.5-Inch HDD x2 / 2.5-Inch HDD x2
- Expansion Slots: 7
- Motherboard: ATX
- System Fan (Front): None
- System Fan (Top): 140mm Fan x 1
- System Fan(bottom): 140mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 160mm / CPU cooler height: 150mm
Only £79.99 inc VAT.
ORDER NOW
Lian Li PC-A55B Aluminium Midi Tower Case - Black @ £79.99 inc VAT
- Motherboard: ATX
ORDER NOW
I think the only draw back with Lian-Li is they're too good. I'm quite happy to just keep using the same case for a decade!
This, I'm still using the one I got back in 2006 lol. I thought about getting another but there really wasnt much point, mine was still perfect size/condition for the task of my new system.
It's amazing how they make such light, compact cases that can fit so much hardware. The V750 is by no means big and yet fully supports XL-ATX motherboards. It's refreshing given how other manufacturers simply make bigger and bigger cases to achieve the same thing...
One example is the Bitfenix Prodigy which is massive for an mini-ITX case and yet the V355 is smaller and can house m-ATX motherboards.
imho, there is a lot of wasted space in the prodigy
myself and Ace Plodder checked out the Lian Li PC-V355B yesterday and I reckon I could easily fit my PC from my silverstone fortress in there as well as a full watercooling loop
Yup, Silverstone and Lian Li are both amazing products, but with some different reasons.
For example - Silverstone use extremely strong solid heavy steel which is impossible to bend or flex. (try it RJK with you side panels on your Fortress, you will fail to bend one with your bare hands) yet the Lian Li range offers lightweight, yet high extreme finishes with some very versitile unique options.
Think the main drawback is cable management is so hard in the mid tower cases, Ive given up trying to make my cables hidden away in my Lian Li, going over to the Corsair side
I thought you guys were going to stop selling Lian-Li cases? Granted this was a while ago now.
I miss my black V1000+. Beautiful case... I quickly learnt to be more patient with my PC as punching/kicking it was beginning to hurt! :D
Agree on the size side of some cases, that Prodigy is very nice looking but honestly thought it was mATX at first.
My SG04 is smaller than the Prodigy and that handles quite a bit of kit in there ATM.
Blimey, thats saying something!
I like the look of the mITX cases...
Maybe the new HTPC to go on the bookcase... roll on Haswell...
Who's holding on for Skylake? :)
