Bigger and Better Lian Li Range
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi Guys.
Just thought it would be good to give you all a heads up on the Lian Li range.
I have introduced many new lines over the past couple of weeks.
Lian Li Range
Here are some of the newer products in the range.
Lian Li PC-V750A Midi Tower Case - Silver @ £269.99 inc VAT
With great innovation spawns great products. The Lian Li PC-V750 is moulded from amazing innovatitive ideas hence the "greatness" of this chassis. With a unique front mounting PSU location and base mounted hard drives (along with the usual front HDD cage too) and an amazing ten expansion slots allows the usage of Quad GPU's and room for other cards, like a SATA controller or a dedicated audio card. Your choice of hardware options inside this case surpasses other options on the market.
- Dimensions: (W) 230mm x (H) 440mm x (D) 586mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- Net Weight: 7.35KG
- 5.25" drive bay (External): 1
- 3.5" drive bay (External): None
- HDD bay: 3.5-Inch HDD x9 ( Hotswap x6) / 2.5-Inch HDD x6 ( 2.5-Inch HDD x3 use 3.5-inch)
- Expansion Slots: 10
- Motherboard: E-ATX / XL-ATX / ATX / Micro ATX
- System Fan (Front): 120mm Fan x2
- System Fan (Top): 140mm Fan x2
- System Fan (Rear): 120mm Fan x1
- I/O Ports: USB 3.0 x 2 / USB 2.0 x 1 / e-SATA x1 / HD Audio
- Maximum Compatibility: VGA Card length: 380mm / PSU length: 210mm / CPU cooler height: 170mm
Only £269.99 inc VAT.
ORDER NOW
Lian Li PC-V750B Midi Tower Case - Black @ £269.99 inc VAT
ORDER NOW
Lian Li PC-V750WX Midi Tower Windowed Case - Black @ £299.99 inc VAT
The "X" Edition case includes an all black interior and a side window to show case your system off.
Only £299.99 inc VAT.
ORDER NOW
Lian Li PC-V355A Aluminium Micro ATX Cube Case - Silver @ £94.99 inc VAT
With advancing technology comes better and better Micro ATX motherboard technology. Overclocking features are becoming more rich on the smaller boards. This is where the PC-V355 case shines, allowing you to build an extremely high end PC in such a small footprint. i3, i5 and i7 rigs and long GPU's all with the ability to be overclocked is a breeze in this chassis.
- Dimensions: (W) 283mm x (H) 263mm x (D) 386mm
- HDD bay: 3.5-Inch HDD x3 / 2.5-Inch HDD x1
- Expansion Slots: 4
- Motherboard: Micro-ATX / Mini-ITX
- System Fan (Top): None
- System Fan (Rear): None
- I/O Ports: USB 3.0 x 2 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 210mm / CPU cooler height: 100mm
Only £94.99 inc VAT.
ORDER NOW
Lian Li PC-V355B Aluminium Micro ATX Cube Case - Black @ £94.99 inc VAT
ORDER NOW
Lian Li PC-Q03A Mini-ITX Cube Case - Silver @ £59.99 inc VAT
The ideal of creating the PC-Q03 is to save user's space, the PC-Q03 can fit Mini-ITX mothorboards and ATX power supplies.
PC-Q03 is designed to maximize the natural flow of air through vent holes located on the side and rear panels to cool components.
- Dimensions: (W) 199mm x (H) 245mm x (D) 210mm
- 5.25" drive bay (External): 1( Slim ODD )
- HDD bay: 3.5-Inch HDD x1 (Using 2.5-inch space)/ 2.5-Inch HDD x2
- Expansion Slot: 1
- Motherboard: Mini-ITX /Mini-DTX
- Maximum Compatibility: VGA Card length: 180mm / PSU length: 160mm / CPU cooler height: 60mm
Only £59.99 inc VAT.
ORDER NOW
Lian Li PC-Q03B Mini-ITX Cube Case - Black @ £59.99 inc VAT
- Expansion Slot: 1
ORDER NOW
Lian Li PC-A55A Aluminium Midi Tower Case - Silver @ £79.99 inc VAT
The new PC-A55 is a great Midi Tower case with a great front mounting PSU deisgn to enhance space and airflow. This chassis offers the usual amazing quality that you always expect from Lian Li with it's brilliant brushed aluminium panels.
- Dimensions: (W) 188mm x (H) 375mm x (D) 455mm
- HDD bay: 3.5-Inch HDD x2 / 2.5-Inch HDD x2
- Expansion Slots: 7
- Motherboard: ATX
- System Fan (Front): None
- System Fan (Top): 140mm Fan x 1
- System Fan(bottom): 140mm Fan x 1
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio
- Maximum Compatibility: VGA Card length: 310mm / PSU length: 160mm / CPU cooler height: 150mm
Only £79.99 inc VAT.
ORDER NOW
Lian Li PC-A55B Aluminium Midi Tower Case - Black @ £79.99 inc VAT
- Motherboard: ATX
ORDER NOW
Lian Li has dropped the ball to the likes of Silverstone sadly. I keep hoping they'll drop the prices a bit and release something new, rather than the same old design slightly reshaped.
