Biggest Hard Drive for PS3
As long as it's a 2.5" Sata then I don't think there's a limit on capacity but I may be wrong. Either way I'd probably go for a 500GB 5400RPM drive, I wouldn't bother with a 7200RPM personally because of the extra heat it might add.
Any 2.5" SATA drive that is 9.5mm tall which not all 2.5"drives are, some are taller, I think they are 12mm or 12.5mm
