Bike crank replacement
28 Nov 2002
Cumbria
I have a Boardman teamR mtb with slicks on that I use for work
The chainset/crank is getting pretty worn and the bottom bracket is on its way out , it's an FSA Comet 10spd double 42 ,27 iirc
I want to replace the whole lot , chain and cassette too
The shifters and derailleurs are SRAM x7
Can I replace it all with shimano or will the SRAM shifters etc affect the setup?
Or would I be best using alternative SRAM components ?
Any recommendations?
I've kind of lost faith in FSA as the bottom bracket has been replaced quite a few times and seems to easily wear and break
You could replace it with a shimano crank if you wanted, it would work fine with SRAM shifters.
