Bike Rack
8 Feb 2004
In the wetlands...
Hi all,
Not sure if best to post here, or in the DIY thread - but figure most cyclists would have had similar issues, so...
I would like to reduce the amount of space our family bikes take up in the garage, is there a suitable system for hanging them off breezeblock walls? I ask as I am never entirely confident with breeze blocks, they always seem a bit too easy to break for me, so if there's a safe and secure system that'd be ideal.
We're only talking perhaps enough for two bikes, but they're not lightweight, around about 15kg (each) I'd say. Also not particularly high value, so don't need to worry about scratches and minor dinks so long as they don't impact on the bike.
Thanks for any suggestions!
I use the lifeline holders from wiggle with very long screws. holding them by their wheel. 6 bikes on the wall this way.
If you want something a bit fancier (and pricer) that swings left/right, Wiggle have the SteadyRack. I've got five of them in my mancave.
Thanks all - some good possibilities there, will plan things out further with the current space and then make a final choice (and hopefully not botch the installation).
Thanks again
