its an old style fitting.. how did you miss it when buying? new post or new saddle for you.
What's the old style?
The rail saddle is off a 10 year old bike and the big saddle was bought brand new a few days ago.
I ordered online and there was no images of the underside or even a mention of its fittings. I just presumed all saddles were dual rails and a clamp.
http://www.jejamescycles.co.uk/etc-steel-254mm-seatpost-silver-id26906.html
You need that style but in the correct diameter. It should be stamped on the old post you still have.
Not a massive range of sizes available so you may be stuck with the newer clamp style.
I'd stick with the old saddle as that is a joke.
I had a look and couldn't find the diameter. I'll whip out my measuring tape tomorrow.
The old saddle is like a G string on my backside. I did 4000 odd miles on the saddle 7-10 years ago. No idea how I managed it.
I took it out for a 6 mile run the other day and my rear is still agony from it, I couldn't even sit for more than 100 metres and had to stand up to ride.
I badly need a comfort saddle.
a saddle that wide is probably going to be even less comfortable
I purchased one of these when I first started cycling as an adult. I stopped using it after a few rides as it was hurting my hips. In fact, I may still have it somewhere - if I can find it, you're welcome to it.
I'll have a look for it when I get home - I'll send you a message via trust if I do still have it.
