Billion BiPAC 7300
Suspended
17 Mar 2006
Will this be a suitable replcement for a Netgear DG814?
Billion BiPAC 7300 4-Port ADSL2+ Modem/Router (NW-004-BI)
Connecting to Pipex DSL, I need the 4 port access (two computers and a squeezebox)
Basically a modem/router/hub/gateway thing all ine one.
Picked one up today, it is suitable replacement for the netgear. flashed firmware ok. need some help setting up port forwarding- is this the correct section? The PC that needs port forwarding is 192.168.1.100
You want the Virtual server section.
Application - Time Schedule - Protocol - External Port - Redirect Port - IP Address
Bittorrent Always On tcp/udp 4534 - 4534 4534 - 4534 192.168.1.40
You also need to either set a static IP on your PC or you can do it the neat way by going to LAN -> DHCP -> Next -> and then Fixed host. I use this as it means that i can plug my laptop in at work without having to change the settings.
Ps its a great router when you know what your doing with it.
Also i don't bother with the firewall its a bit ott for my uses, i just use nat and makesure i know whats running.
