BIOS and CPU-Z not matching?
29 Dec 2011
England
Ok so I decided to overclock my CPU so I went straight for a pretty bog standard 4.2GHz @ 1.15V in the BIOS yet when I run CPU-Z it states it's running at 4.2Ghz @ 1.080-1.072V (flicks between the two) and yes this is under load in Prime95.
So I'm rather confused as to what is happening here???
Either way its been stable for 8hours under Prime95 Large FFTS over night, but I am curious which is the correct "reading".
probably both right, but as you put the CPU under load you have Vdroop (so CPU-Z reading a lower value), which is where LLC option comes in.
What should I set the LLC to to compensate? Also does this mean the CPU is stable with 1.072V @ 4.2GHz?
No idea as you are using a board I've not used, try a middle figure and see whats then reported.
But....how accurate can a piece of software be? a digital multi meter is the best way to get a true Vcore value.
hmm a valid point although I don't own one lol :/ I'll try a middle figure and see what it says :)
