The file extension doesn't matter as long as it is a BIOS file. The name will vary by manufacturer. Most BIOS flashers will verify the file before overwriting anyway and tell you if it doesn't look right.
Varies with BIOSes, just point to the file if flashing from windows or type in the file name if in DOS, if its wrong the flash will more than likely abort.
My problem is that I've put the .bin and the renamed .rom file on my pendrive and gone into ez flash in the bios but I can't find the file, I have A:, B:, C:, D: and I look in each one but nothing appears ...
I think with EZFlash the filename has to be exact or it won't use it. Probably 'BIOS.ROM' or 'BIOS.BIN'. It should say in the manual what it must be called.
Actually I think looking on the Asus website it can be called anything and you load load it when EZ Flash is loaded.
Simply put the file on your pendrive, make sure it's formatted to fat 32 and then go into set-up during boot and run EZ flash from there. It's really easy! You will see your pen drive listed and be able to select the rom from it. It should be a .bin file.
