Just flashed my striker2 yesterday with the 1001 bios Since then my mouse razer copperhead just turns itself off for no reason un-plug and plug it back in and it works
Could this be down to the bios or is my mice getting faulty?
You mean when you start up the PC it wont work? If so its a common fault witht the mouse. I think you can flash the frimware of the copperhead which will sort it
