BIOS Freezing?
6 Apr 2004
Bath, UK
I went out today - leaving my computer on downloading, turned the monitor off etc. Came back and my pc was turned off at the wall, flicked them on and my monitor was still off so im guessing some one in my house has turned my pc off at the wall. This seems to have reset the clocks on my cpu as everything else is normal. Now when i go into the BIOS it hangs. Any ideas?
are you sure its actually freezing,
When it locks up just press the alt keys, alt, altgr and then the ctrl keys and also try the shift keys.
Used to get this on a couple of asus boards i had, a combo of the above always sorted it out lol.
God know's what causes it though.
