BIOS Help
5 Sep 2009
Hi all I have a bit of a problem, bear with me I am a bit of a noob with this.
I am trying to troubleshoot a system I am setting up for my sister, I have installed a sata HDD (before a IDE was installed which worked with windows xp) but when it boots up it now comes up with "PXE-E61 boot failure".
I have tried going through bios to try sort it but thats another problem, when I try to save and exit the bios it gets stuck on the Y/N confirmation, it just flashes with "Y", I can't type anything, no Y, N or enter, nothing, always have to reboot to get out of it, so in the end I can't save anything. Now I'm thinking I could give flashing the bios a try, do you think I could do it through usb stick without needing to touch the bios settings? or would I need a floppy disc?
I'm not sure if its got anything to do with it but the pc hadnt been used for a year so the cmos battery was flat and I had the "cmos checksum error defaults loaded" error. It is now replaced though and the error doesn't come anymore.
motherboard is foxconn 865A01-PE-6EKRS
sata HDD is 160GB Western Digital Caviar WD1600
DVD drive is IDE
Would anyone have any other suggestions I could do?
Help would be apreciated.
I would use a floppy disk as many older bios versions had a boot sector that searched for the A: drive and USB is not always recognised until later.
PXE-E61 boot failure is associated with network booting and network booting should be disabled when the bios is restored. Also if you have more than one hard disk remove it.
Check that there is no conflict with master settings between hard disks.
andy.
