bios help
12 Jun 2017
hi :) i have installed my asus amd cross-hair Vl hero
i am looking for the page with my BIOS ! i can only find rog asus cross-hair hero
and im not shore if mine is rog! this is the one i got :)
asus amd crosshair Vl hero ! dose not have Rog in the name
if sum1 could help me find the right page thanks :)
Ok... so your post is awfully confusing... There is only one CH VI hero. The bios page is the bios page. There's only one bios for your board, which with ASUS you usually get to by spamming delete when you turn the machine on.
I wonder what you mean by "page"? Just in case... Just in case you are looking on the web for a BIOS update .. DON'T ! Never, ever update the BIOS unless you are two trillion percent certain. Put it like this, I have a large bin full of motherboards that have been "updated" ~ mostly with the wrong BIOS, occasionally with ones that just, well, who knows why they failed? I would only recommend you update the BIOS if you have a problem and the manufacturer specifically says "this fixes it". Otherwise just don't go there. It's way, way too dangerous.
Why not reprogramm the bad bios instead of leaving them in a bin
That's just user error, make sure you have the correct bios. I've heard msi boards can be a bit iffy, but I've flashed several gigabyte boards over the last year with no issues at all.
Never had any problems flashing. And some have dual bios so should be impossible to brick.
And even flashing android rom not pc motherboard but done them lots no problems, and risky if you miss a step.
