Ok so this morning i turned on my computer after it was off all night, and within a few seconds of it powering up, it started beeping and said on the screen "CPU temp too high" or something like that. So i went into the BIOS screen and checked the temp, it said 79°C, how could this be, the computer was only on for less than a minute.
Also ASUS PC probe II reports temps of the same magnitude.
BUT, when i use coreTemp to meausre the temps, its gives me a much more reasonable temperature of between 30 - 35°C.
What might be a factor is, a few weeks ago, i was in a rush to get out of the house, so in my haste, as my computer was shutting down, i turned it off at the wall, As soon as i did this i realised my error. And since then the BIOS has been giving these high temps, which seem to get higher every week, but coreTemp is giving the more realistic (and constant) values.
my question is, why is this happening, and what can i do to stop it, because i had to torn off the setting to give me a warning because, well i dont want a false warning everytime i start my computer
The heating in the room my computer is in is broken and constanly on, so its quite warm in here, so thats why coreTemp is giving 30+°C value, but before the healing was broke, CPU temp would give values like 24-27°C.
Specs:
CPU : see picture not overlocked
MoBo: ASUS M4N82 deluxe
Ram: 4gb
cooler on CPU : Zalman CNPS10X Extreme
Specs:
Ram: 4gb
