BIOS keeps 'fogetting' hard drive order
7 Nov 2012
UK
I've installed a SSD in my dad's old (4-5 yrs) Dell desktop and put Windows 7 on it. There is also a SATA DVD & HDD in the tower.
SATA mode is IDE; the only alternative is RAID.
Every time the PC power cycles I get a dos screen saying there's no boot device, but lists the SSD (with the HDD & DVD). I go back into the BIOS and the SSD has dropped down the list of bootable drives again.
I can move it back up to #1 and the PC boots. Or, I can F12 and manually select the SSD.
I've changed the battery and updated to the most recent bios available (from Dell's site).
I'd rather not remove the SSD and put the OS on the HDD, but if I can't resolve the issue I may have to. Could it just be that the mobo doesn't support SSD?
I wondered if anyone had any suggestions?
If you go into disk manager what is the order of the Drives? Is the SSD Drive 0?
If not perhaps if you change the leads around to put the SSD as drive 0 then it will always go to this?
Mel
SSD is SATA 0.
I have set SSD above the HDD and removed floppy and DVD from the equation.
However, the problem persists - after a reboot, I get the 'no boot device screen' and going into the bios I discover the SSD has dropped back down below the HDD.
Out of question, I assume you have tried resetting CMOS?
Also, have you considered changing the BIOS battery? When it forgets the drive order, does it also forget the time?
