Bios not showing correct voltage
7 Dec 2008
Hi guys,
I am using a Sandybridge 2500k with an Asus Z877-I deluxe motherboard. Currently I am at 1.350v manual mode to achieve a stable 4.5Ghz, however my bios after doing so is reading 1.360v for some strange reason.
Anything I can do fix this?
for reference my other volts are at :
Dram 1.500v
VCCSA: 0.925
Thanks guys.
Rounding error?
maybe you're closer to 1.355?
After doing some tweaking, I have set it to offset mode and started adjusting the voltage incrementally, I am not at 1.344v - 1.55v (it fluctuates) when running prime95, and max was 60c. Idle i am at 0.944.
I will continue to have a play around. Now I am going down in voltage finally, I don't mind experimenting.
