- 8 Jan 2009
- Northern Ireland
What it is, I have a Dell Inspiron 570 with Win 7 HP with SP1, and BIOS A05. I formatted a USB stick to these instructions HERE, and can't boot off the stick. I have tried BIOS A04 as well, also I have tried Win 7 Pro(Retail), and Win Vista(Retail) to no luck. Is anybody having problems booting off a USB stick with Win 7. What happens is,
1. Put in USB stick to USB port.
2. Reboot System, then Press F12.
3. Select USB Disk 25X( That what it says on the F12 menu).
4. Press Enter.
What happens then is, a message comes up saying, "Remove Disks or Other Media", then "Press any Key to Restart". I'm almost sure it's not my 256MB USB stick, it could be the BIOS which is stopping the USB Stick from booting, if so, then i have a problem. Any ideas. Thanks Robin
4. Press Enter.
From checking those instructions above, your USB key needs to be at least 4 GB in size.
