Bios Problem
1 Apr 2007
Ive got a Pheonix Award Bios. When I go into the HT settings there are no options to change the value. I cant escape back out of the HT setting menu but have to reboot the PC. The default value is 5. Any ideas ?
My Mobo is a K8N Neo2 Platinum. Is my Bios bugged or is it locked for some reason ?
Have you set the overclocking options to manual? Some of the advanced options will be "Greyed out" if options are set to auto mate :)
