bios reset but still at overclock speed
19 Oct 2013
Hi all
I received my haswell MB and processor bundle a couple of days ago and finally got it put together. However when powered up nothing came up on the screen. I found a suggestion on the net to unplug the monitor, fire up the tower then plug the monitor back in. Success.however it stated the bios had been reset but noticed it said within the bios that the processor was running at 4.5 which is its overclocked speed from 3.5. Ive installed windows and game and very happy with its performance. I checked the " how to reapply your overclock" section of the forum and checked bios for the ocuk profile 1 but its not in the bios. Should I have anything to worry about in this case even though it seems to be running at the require oc.
Regards
Steve
thanks for your replies, cannot understand how it reset but kept the overclock speeds. i have used cpu z and prime which confirms the speeds, and have put it through 8 hours of hard gaming, perfect performance. thanks again.
