bios setting cpu margin enhancemeant?
23 May 2009
London
hi guys wat should the cpu margin enhancement setting be in the bios.
my cpu is q9550.
and also i have a 5870 gfx wat should my pcie frequancy setting be in bios?
my cpu is q9550.
I think i just left mine on optimised and it works perfectly fine. Has ran prime for quite a few hours so i'm happy. However some people have had issues leaving it at this and set it to performance so its just a case of finding out. Could always set it to performance to be on the safe side. Also PCIe frequency should be set to 100mhz.
On my previous q9550 p5q deluxe combo, i found that changing it from optimized to performance helped stabilise my overclock, particularly when running prime95 blend.
