Can some one just check these numbers
Spec
EDIT: RAM IS Geil PC6400 C4 1GB*4
Had a slight problem a year into running this and had to mess about with bios to get it working again, did factory defaults and that but kept getting blue screen of death had to manaully set the ram voltage to 2.1v
So on my bios i see
Intel pentium dual cpu E2180 @ 2.00ghz
CPU Operating Speed : User Defined
External speed : 200mhz
Multiiplier factor: 10X
Estimated New Speed 2.00ghz
DRAM Speed (CPU : DRAM) Default DDR2-800
(options are 1:1.00 ,1:1.20 , 1:1.25 , 1:1.50 ,1:1.66 , 1:2.00)
PCI Express Frequency:100 MHZ ( options are 100-200)
Voltage Control Manual
CPU Core Voltage :1.3250V
DDR2 Voltage: 2.1 V
CPU VTT Voltage: 1.2000V
ICH 1.50V Voltage: 1.50V
MCH 1.25V Voltage: 1.25V
CPU GTLREL(?) :63%
Temperateures
CPU Temp 32C
System Temp 25C
PWM Temp 37C
TIA
Spec
Gainward BLISS GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) -
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) -
Pioneer DVR-212DBK 18x DVD±RW SATA Dual Layer ReWriter (Black)
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
Antec NSK 6580 Super Midi Tower Case - 430W Earth Watts PSU
OCZ 2GB (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series
Western Digital Caviar SE16 400GB SATA-II 16MB Cache - OEM
So on my bios i see
DDR2 Voltage: 2.1 V
CPU GTLREL(?) :63%
Temperateures
CPU Temp 32C
System Temp 25C
PWM Temp 37C
TIA
