BIOS Settings
13 Dec 2010
Hi,
Will soon be putting together my new build:
i5 760
4gb 1333 OCZ Gold RAM
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard
Please can someone help with BIOS settings?
BIOS Settings should be automatic. Both your CPU and Memory will be set at the same FSB frequency of 1333MT/s so there should be no problem.
If you're wanting to look at overclocking, you could easilly get the CPU upto 3.2/3.4GHz with good cooling. This is done by setting the DRAM Frequency higher, which will affect your CPU Core via the Multiplier.
You should take a look at the overclocking guide.
yep as above you need to read up on this. no point anyone giving you a list of settings to use as every cpu chip is different and plus if anything goes wrong you wont know how to fix it!
loads of guides out there..
