BIOS update using USB stick
12 May 2005
In this article Toms Hardware use a USB flash stick to update the motherboard BIOS. They say they have made it bootable using the HP utility here.
Couple of questions:
- would that HP utility work with any brand of USB stick?
- how would the BIOS update usually be done - would it be an .exe file that has to be run from a command prompt?
You can see I am out of my depth :)
Bryn
what board ?
The Asus mobo I have has a section in the bios pages to update from a stick. Best bet if you are unsure is to go to the manufactures web site. AFAIK they all have utilities to use and instructions.
Thanks for the reply Mr O. Any thoughts on the HP utility and its general applicability ( or not) ?
Bryn
