Hi all,
Heres a solution if you've bought Bioshock and found the game won't activate saying "An online activation cannot be performed. Please contact your software vendor to manually retrieve your unlock code"
*Warning By disabling startup programs you do so at your own risk*
1. Click on START and in the search box or run menu type: msconfig then press enter.
2. Select the STARTUP tab and click on the 'Disable all' button then click ok and reboot your computer.
3. Put the Bioshock DVD in the drive and when the Bioshock menu appears click on the 'Run' option. The game will now ask you to enter your code again, anter your code using capitals and minus (-) signs. Basically as it looks on the back of the game manual. You'll find the game will now activate fine. When activation is complete the game is unlocked and ready to play but before you do this move on to step 4 & 5
4. Click on START and in the search box or run menu type: msconfig then press enter.
5. Select the STARTUP tab and click on the 'Enable all' button then click ok and reboot your computer.
Have fun with Bioshock.
