Bioshock coming to iOS (iPhone 5/5s/5c, iPad mini 2, iPad Air)
24 Jun 2008
Just seen the news online, I'm wondering how close they manage to get it graphically to the original - it's good in a way that they have limited it to fairly new hardware so we can finally see what the newer mobile chipsets are really capable of (although I would have dropped the 5 and 5c also :p)
Anyone plan to get?
It’s not looking very good graphically from the little bits I have seen. Far worse then current mobile games.
The problem seems to be space more than hardware they have a 2gig file limit and so had to remove/reduce a lot of things to fit into the space requirements even if the hardware could have run them.
EDIT: quote
"In order to work better with iOS hardware and to fit into the 2GB size limit imposed by Apple, the game will feature slightly scaled-down graphics. This means that certain gameplay elements such as shadows and fog won’t be as elaborate as those in the console version. "
Looks like its a port of the console version not the better looking PC version.
Really? You expect them to port the PC version with high res textures? :p
I'm not defending the 2GB cap (although I see why that's there), if they can port the console version to a phone, they've done well IMO.
Hopefully if they bump the minimum size of the iPhone/iPods they'll bump the 2GB cap.
With the PVRTC2 texture compression I cannot see why they cannot have high res textures. Hopefully they use that and to make up for some of the space restrictions. But that’s still what 5 to 8gig of other data that somehow needs to be cut out?
Wish I'd seen this thread just bought it for my ipad retina (4g) and it doesn't work.
It says it's compatible with Ipad 4 but simply doesn't get past the splash screen. :(
Would loved to have had it but won't buy a new ipad for it
Apple were very quick to reimburse.
EDIT : Just read that it's currently incompatible with iOS8.4.
Hope they get it fixed soon.
Will rebuy it if they do.
