Bioshock demo crashes
5 Dec 2006
Hampshire
Anyone else having the problem where if you have HIGH RESOLUTION SHADERS (or High quality, whatever) turned on, it crashed totally just before you come out of the submarine into the main city?
It comes up, you see the guy and the shadow of the splicer, the sound carries on, then the game just locks up totally. not even Ctrl alt Del fixed it, I had to hold the power button down.
It did exactly the same thing the second time I tried, but didnt when I turned off high quality shadows.
it was running really nicely, and my card should be able to cope - Overclocked 256 MB Geforce 6800 (its old yes, but it runs the rest of it perfeclty well)
I hope this is just a problem with the dmeo, as turning off high quality shaders takes away many of the stunning lighting effects.
