bioshock demo refuses to work
12 Jun 2007
East London
Hello
i have downloaded the bioshock demo firstly from steam. tried launching it every way possible, just doesnt work. nothing happens. it appears in task manager for about 5 seconds, then goes. thinking maybe the download was borked i downloaded again from an ftp source, same thing. it insalls fine, but nothing happens when i launch it from the start menu.
any help is appreciated as i want to know what the hype is all about
my set up
xp home 32bit sp2
Q6600 @2.7
8800gts 640
2gb ddr2
p5ne-sli onboard audio
the newest nvidia drivers 163.44
please help me out lads
cheers
I am having problems too - plays fine but the sound goes off just after the plane crash and then when I press the volume buttons on my laptop they bring up menus instead???
Dont think anyone had problems in the big thread, I'd check over at the 2k forums.
Yeah my logitech keyboard volume control does that, it does change the volume though.
ergonomics said:
Hello
my set up
Q6600 @2.7
8800gts 640
2gb ddr2
cheers
tried to clock your system back to stock speeds?
no, but im confident that a small overclock is not what is causing this, when ive seen others running it with heavily oc cpus and gfxs
If you are on Vista run the demo in XP Compatability mode and you will get sound, however it will most likely be stuttery bad quality sound. I have the same problem with my card as im using forced 3rd party drivers to get any sound out of it at all, it's a first gen SB:Live must be some 8 years old, so naturaly not supported by Vista or even creative labs anymore.
Nope, tried that and it still doesn't work! I'm not running an old sound card either - it's a DELL XPS M1710 laptop which is only just over a year old so it should run fine. I read on the 2K forums that another guy was having the same prob as me and he had a DELL system also with the same built in sound as me. There was not a solution posted to his problem though!!!
Just dl the demo and im having problems :p
I got onto the main menu changed the settings to max except the dx10 ones of course. And i clicked onto play demo then i got a blue screen and my pc restarted :(
KNiVES said:
The Steam demo does not work with Vista x64. Got bit by this bug the hard way.
ah there you go - im running vista 64. Got a link for downloading it without steam?
furnace said:
Yeah same problem as you :( But it doesn't even get into the taskbar, just thinks then forgets!
ah no mine doesnt even get that far. it appears in the task manager as bioshock.exe, then goes after few seconds.
getting too annoyed with this game and i havent even played it yet :mad:
Got sound working now - went to Dell.co.uk and had to download and install the official drivers again!!! :D
