Bioshock Help
Don
23 Oct 2005
North Yorkshire
I've finally come back to this game which I stopped playing after I got stuck!
I'm stuck on the Splicer mission, basically photographing three Splicers.
I don't seem to be able to get to the Upper Wharf, there is a gate blocking my entrance into the place.
can anyone remember how you do it?
Thanks!
Piccy if refreshes anyones memory?
Cheers Danny, I couldn't find anything on there relevant but I've done it now. Unbelievable! I haven't played this game since August and got sick to death of it, all I had to do was take a picture of the DEAD splicer I walked past numerous times!!
Back to it then :D
Back to it then :D
Its always the simple stuff that holds up a game like that :) I never had that issue because I photographed everythign I could all the time until the stats where maxed for the achievements.
Just max out all the wrench weidling stats and forget about guns. Save them for Turrets and bosses :D
Did you guys ever progress to the next level without enough Adam? I'm sick of hunting for the little sisters on this level I'm on but am warned not to progress as I haven't saved them etc.
Depends if you want achievements or just to finish the game. I saved all that I should and had loads of extra adam despite buying all I needed for unlocks.
I would save them all to be honest... It makes the game more fun later on - you can afford much better plasmids, tonics and you get more health etc. It makes it easier too! Make sure you look everywhere for ammo though as its hidden allover the place, it makes it SO much easier to playthrough
The more you put into it Andy the better, this includes searching every where for ammo (you'll need it), searching all the bins and creates, you'll need it for hack tools, take everything.
I found hack tools absolutely invaluable, you can only carry a small amount of cash, so use those hack tools on the vendo's and stock up on Eve and health :)
