Bioshock help
Caporegime
21 Oct 2002
Here
Ive saved just before the end battle and have gone back through most the levels hoping to find sander cohens room.
However I can't find Olympus heights anywhere, is it possible to get back to it?
you can do one of two things if i remember correctly
Go to the ol'Rapture metro, pull the lever and select olympus heights
or
Go to Apollo Square in the bathesphere thing. I don't think Olympus Heights is actually marked on the map, but on the map you will see a long passageway that appears to lead nowhere. Head down that way and you should finds signs saying olympus heights and then a bulk head leading to it
Cheers dude, Ill give it a try.
I have done it on medium and got 850g on the first play though. I think hard should be ok once you get the decent weapons.
Did you kill Sander Cohen when you met him? If you did then you won't get the achievement for finding his room.
I played through hard the second time round and it was easy enough.
I saved the game, killed him, reloaded and then let him walk by, opening up the tonic.
Perfect mate, well remembered.
Yeah... there's only two places you can never return to - 1) the initial bit before you go through the toilet wall and 2) the level you travel to where you meet Andrew Ryan. Worth bearing in mind if you're going for the 'historian' achievement (collecting diaries), as there's five in those two locations (2 in the first bit, 3 in the second - from memory).
I picked up a lot, cant remember them first 5 though. Anyway of checking progress?
Mind you i though i was doing well, but on my hunt for bits to make 100 inventions (just done that) i found 4 more. I hardly used the map too as i missed some rooms.
I have 2 power to the people to find, ones in Cohens room i believe
Cheers for help, done it all now other than hard and vita.
I missed one of the 5 diarys too though, so i'll have to leave that for another playthrough.
Took me ages to find the last power to people, turns out it was the 12th one i checked and was in a really obvious place (in Arcadia). Then i spent about 15mins pressing A whilst surfing the net to get the gambling achievement lol.
I think i'm gonna have another play through of bioshock reading you guys talking about it :) such a great game!
I lost my 800ish points when I changed my xbox :(
