Bioshock save
Caporegime
21 Oct 2002
Here
Where do u start from when you save this game?
A certain point or exactly where u save?
Cheers
Cheers for the fast reply
So you may aswell keep saving then. This way you dont need a vial chamber?
I just found the telekenesis plamid. First enemy i see i test it out on, only to pick up a gas cylinder next to her and throw it back blowing her up :D
No, use the Vita Chambers. When you fight the bigger enemies, the amount of damage you do to them is preserved, i.e. if you knock them down to 50% health and get killed, it stays at that level so you can go back for another go. If you reloaded your game, they'd be back at 100% health and you'd probably still get *******.
I'm going for the Brass Balls achievement now. Only need that and Research PHD to fully complete. Even though this is my 3rd play through I still love this game. Joint best SP game of this generation IMO along with Dead Space & COD4.
I love this game so much that on the PS3 I have the platinum and on the 360 I have 1100/1100 achievements (my bro bought it on 360). I don't think you need the vita chambers and I have never used them, even on superhuman on the PS3 towards the end of the game your near enough invincible. To start off with might take a few trys against the Big Daddies but just save the correct ammo and you will be fine.
Can't wait for Bioschock 2, I hope its good :D
My only criticism was how easy it is really. Excellent game though :p
