Biostar I45, Q8400 (overclock help)
Hi
I tend to go higher and then work the volts down once I get the clock I want but as long as we get free Mhz we are happy right :D
good luck,
I think you are gonna love this board
Ok so ive oced this so far
3.6 Ghz 400 FSB X 9.0
Northbritch Bsell - 1333 FSB
Voltages
CPU +0.075
DDR2+0.200
Chipset+0.075
FSB AUTO
CPU PLL volatge 1.5v
Running prime95..... the LARGE test.. running 30 mins now.
100% load Max temp 48 degrees. Minimum 37 degrees.
CPUZ - Volatge 1.216v (core)
Do these settings look ok to you guys ?
this energy saving this seems to be active, even though ive turned off C1, speedstep etc... it keeps my 425 cpu freq FSB, but switches between X6 and X9 multiplier.... going from 2.6 to 3.8 (3.8 when at higher loads) and vice versa.. shal i just leave this ? suppose its not doing any harm not having my processor at 3.8 all the time... maybe healthier :D
