Biostar Ideq 200N bootup problems
18 Oct 2002
Behind the bike shed
I am running the latest BIOS
Using a 80GB SATA drive
When I boot for the 1st time on my Ideq 200N I get the following message and after pressing "G" it boots fine but as this is my server and I want to put this in the garage at some pint I need to make sure it will boot every time as it will have no monitor connected to it. Doing a restart however doesn't bring up the same problem
Also I have a 320GB external HDD attached that I use for backing up atm but if it's connected at bootup I get this message so I have to detach it and plug it back in when it bootss up which is not practical.
Any ideas on the above 2 points please?
Cheers
Do you have any USB boot devices set int eh boot up sequence in the BIOS? maybe have a play and just have HDD set to first boot? maybe disable alternate boot also.
