BIOSTAR MOTHERBOARDS INSTOCK NOW!
11 Dec 2005
Cheshire
Biostar TA890FXE AMD 890FX (Socket AM3) DDR3 Motherboard @ £104.99 inc VAT
The Biostar TA890FXE is based on the AMD 890FX Chipset providing excellent overclocking potential.
BIO-unlocKING technology enables the ACC function on AMD processors and unlocks extra 3rd or 4th core with a super-simple click on the keyboard. 2-phase independent power design increases memory voltage stability and durability. With armor-plated Biostar Technology, all capacitors are placed with 100% solid capacitors that have a lasting life cycle, durability and stability for crucial components. BIOSTAR G.P.U (Green Power Utility) is a new function that enhances energy efficiency by disabling extra phases while CPU is under light loading. It integrates a friendly GUI to monitor the resourcing and response of your CPU thus optimizing the power saving function in your system. G.P.U. constantly sets up the best power efficiency in your system, be it for heavy 3D gaming, Internet or MSN charting.
- CPU: AMD Phenom™ II X6 Processor, AMD Phenom™ II X4 Processor, AMD Phenom™ II X3 Processor, AMD Phenom™ II X2 Processor, AMD Athlon™ II X4 Processor, AMD Athlon™ II X3 Processor, AMD Athlon™ II X2 Processor, AMD Sempron™ Processor
- Maximum CPU TDP (Thermal Design Power) : 140Watt
-HT: Support HT 5.2G
- Memory: Support Dual Channel DDR3 1800(OC)/1600(OC)/1333/1066/800 MHz, 4 x DDR3 DIMM - - Memory Slot: Max. Supports up to 16GB Memory
- Expansion Slot: 2 x PCI Slots, 4 x PCI-E x16 2.0 Slot (x16,x16, x4, x1), support CFX x16
- Storage: 5 x SATA3 6Gb/s Connector, 1 x eSATA2 3Gb/s Connector, 1 x IDE Connector, Support SATA RAID: 0,1,5,10
- USB: 6 x USB 2.0 Port, 3 x USB 2.0 Header, IEEE 1394, VIA VT6330, 1 x IEEE 1394a Port, 1 x IEEE 1394a Header
- Audio: Realtek ALC892 8-Channel HD Audio
- Rear I/O: 1 x PS/2 Mouse, 1 x PS/2 Keyboard, 1 x eSATA2 3Gb/s Connector, 1 x FireWire IEEE 1394a Port, 6 x USB 2.0 Port, 1 x RJ-45 Port, 6 x Audio Connector, 1 x S/PDIF Out Port
- Form Factor: ATX Form Factor Dimension: 30.5cm X 24.4cm ( W x L )
- Accessories: 4 x SATA Cable, 2 x SATA Power Cable, 1 x I/O Shield, 1 x CD Driver, 1 x User Manual
- Warranty: 2 Years
Only £104.99 inc VAT.
ORDER NOW
Biostar TA890GXB-HD AMD 890GX (Socket AM3) DDR3 Motherboard @ £69.99 inc VAT
The Biostar TA890GXB-HD is based on the AMD 890GX Chipset with powerful overclocking potential and intergrated graphics. Play HD content out the box including 1080P. A microATX Form Factor allows users to install the TA890GXB-HD in smaller chassis for a more compact desktop solution.
- CPU Support: AMD Phenom™ II X6 Processor, AMD Phenom™ II X4 Processor, AMD Phenom™ II X3 Processor, AMD Phenom™ II X2 Processor, AMD Athlon™ II X4 Processor, AMD Athlon™ II X3 Processor, AMD Athlon™ II X2 Processor, AMD Sempron™ Processor
- Maximum CPU TDP (Thermal Design Power) : 125Watt
- HT: Support HT3.0 up to 5.2GT/s (Depends on AMD CPU Specification)
- Memory: Support Dual Channel DDR3 1600(OC)/1333/1066/800 MHz, 4 x DDR3 DIMM Memory Slot, Max. Supports up to 16GB Memory
- Expansion Slot: 2 x PCI Slots, 1 x PCI-E x16 2.0 Slot
- Storage: 6 x SATA3 6Gb/s Connector, Support SATA RAID: 0,1,5,10
- USB: 4 x USB 2.0 Port, 3 x USB 2.0 Header
- On board Grpahics: ATI Radeon™ HD4290 Graphics , Max. Memory Share Up to 512 MB Support ATI Hybrid Crossfire
- Audio: Realtek ALC892 6-Channel Blu-ray Audio
- Rear I/O: 1 x PS/2 Keyboard, 4 x USB 2.0 Port, 1 x HDMI Connector, 1 x DVI-D Connector, 1 x VGA Port, 1 x RJ-45 Port, 3 x Audio Connector
- Form Factor: Micro ATX Form Factor Dimension: 24.4cm X 23.3cm ( W x L )
- Accessories: 3 x SATA Cable, 1 x SATA Power Cable, 1 x I/O Shield, 1 x CD Driver, 1 x User Manual
- Warranty: 2 Years
Only £69.99 inc VAT.
ORDER NOW
Biostar H55A+ Intel H55 (Socket 1156) DDR3 Motherboard @ £69.99 inc VAT
Biostar's entry level full ATX H55 Chipset motherboard. Featuring support for Intel i3/i5/i7 Series 1156 CPUs. With DVI, HDMI and VGA output this motherboard is a solid choice for a first computer.
- CPU Support: Intel® Core™ i7 LGA 1156 Processor, Intel® Core™ i5 LGA 1156 Processor, Intel® Core™ i3 LGA 1156 Processor, Intel® Pentium® LGA 1156 Processor
- Maximum CPU TDP (Thermal Design Power) : 95Watt
Memory: Support Dual Channel DDR3 1866(OC)/1600(OC)/1333/1066 MHz, 4 x DDR3 DIMM Memory Slot, Max. Supports up to 16GB Memory
- Expansion Slot: 2 x PCI Slots, 1 x PCI-E x1 2.0 Slot, 2 x PCI-E x16 2.0 Slot (x16 +x4)
- Storage: 6 x SATA2 3Gb/s Connector
- LAN Realtek RTL8111DL - 10/100/1000 Controller
- Audio: Realtek ALC662 6-Channel HD Audio
- Rear I/O: 1 x PS/2 Keyboard, 4 x USB 2.0 Port, 1 x HDMI Connector, 1 x DVI Connector, 1 x VGA Port, 1 x RJ-45 Port, 3 x Audio Connector
- Accessories: 2 x SATA Cable, 1 x I/O Shield, 1 x CD Driver, 1 x Quick Guide
- Form Factor: ATX Form Factor Dimension: 30.5cm X 21cm ( W x L )
ORDER NOW
Biostar TH55B-HD Intel H55 (Socket 1156) DDR3 Motherboard @ £64.99 inc VAT
Biostar's entry level microATX H55 Chipset motherboard. Featuring support for Intel i3/i5/i7 Series 1156 CPUs. With DVI, HDMI and VGA output this motherboard is a solid choice for a first computer.
- Memory: Support Dual Channel DDR3 800/1066/1333/1600(OC)/1800(OC)/2000(OC) MHz, 4 x DDR3 DIMM Memory Slot, Max. Supports up to 16GB Memory
- Expansion Slot: 2 x PCI Slots, 1 x PCI-E x1 2.0 Slot, 1 x PCI-E x16 2.0 Slot
- Storage: 6 x SATA2 3Gb/s Connector, 1 x IDE Connector
- Form Factor: Micro ATX Form Factor Dimension: 24.4 cm X 24.4 cm ( W x L )
- Warranty: 2 Years
Only £64.99 inc VAT.
ORDER NOW
Biostar G31D-M7 Intel G31 (Socket 775) DDR2 Motherboard @ £29.99 inc VAT
The classic G31 Intel Chipset provides excellent value for money, reliability and 1080P video playback via the Onboard graphics.
- CPU Support: Intel® Core™2 Duo Processor, Intel® Pentium® Dual-Core Processor, Intel® Celeron® Dual-Core Processor, Intel® Celeron® Processor 400 Sequence
- Maximum CPU TDP (Thermal Design Power) : 65Watt
- FSB: Support FSB 800/1066/1333MHz
- Memory: Support Dual Channel DDR2 667/800 MHz, 2 x DDR2 DIMM Memory Slot, Max. Supports up to 4GB Memory
- Expansion Slot: 1 x PCI Slots, 1 x PCI-E x16 Slot,
- Storage: 2 x SATA2 3Gb/s Connector, 1 x IDE Connector
- USB: 4 x USB 2.0 Port,1 x USB 2.0 Header
- LAN: Realtek RTL8102EL - 10/100 Controller
- Onboard Graphics: Intel Graphics Media Accelerator 3100 On Board Graphic Max. Share Memory 256MB
- Rear I/O: 1 x PS/2 Mouse, 1 x PS/2 Keyboard, 4 x USB 2.0 Port, 1 x VGA Port, 1 x RJ-45 Port, 3 x Audio Connector
- Accessories: 2 x SATA Cable, 1 x I/O Shield, 1 x CD Driver, 1 x User Manual
- Micro ATX Form Factor Dimension: 22.5 cm X 17 cm ( W x L )
Only £29.99 inc VAT.
ORDER NOW
Nice to see Biostar back in the game again. I was building hundreds of them about ten years ago. They were very understated boards with solid performance and a good price point.
We sold loads of Biostar iDeq's which outsold Shuttle 2:1 due to build quality and quietness. Still got my AMD 3000 with 2GB ram, and its running Win7 Premium no probs... its years old!
That 890FX board looks like a damn good deal, 2x pci-e x16 for that price :O, no sata 3Gb/s or usb 3.0 though :(
I just ordered the 890FX board, although there is no usb3.0, i figured by the time i use usb3.0 the pci cards wont be all that expensive :P
TA890GXB-HD looks similar to mine but missing a few heatsinks!! what's the difference between this and the GXE version?
biostar motherboards are cr@p tbh , had 2 die on me running stock speeds . nice looking boards but not for me
I've had 2 Asus boards die on me and a Gigabyte board. Not a single Biostar board has given up on me yet.
Biostar are not **** by any stretch of the imagination, you must have just got unlucky. I've been very happy with Biostar for years and years. Speak as you find, I'd highly recommend them
Thought they're gone bust tbh. Must have been a while since their last product launch? Good to see there still about, I have a couple of workstations running Biostar boards, wouldn't hesitate to buy one again
Just noticed, they've ditched the lurid colour schemes :(:) that was a feature IMO
