at the moments im running 3.8ghz with the following settings
multiplier: 20
blk: 190
dram: 1528 @ 1t
uncore: 3000ish
voltages all auto expcept:
vcore: +.100
dram: 1.660
QPI/PCI PLL: 1.290
so im running at 3800mhz with speedstep/turbo all off
however when i try to get a good 3.6ghz clock with upping my ram frequency I get blue screen.
Ive been trying
18 x 200 with the same voltages as before, 3000ish uncore and ram at 1600
the ram is at 7 7 7 18, so is the extra 72 making is crash?
im a little bit puzzled because i cant get it to get stable at all.
Also how do i get about clocking down the ram latency slightly, as in the picture below I dont have a clue what the bottom half numbers are.
here are 2 screen shots of the what the standard bios looks like to help you understand, thanks
multiplier: 20
blk: 190
dram: 1528 @ 1t
uncore: 3000ish
vcore: +.100
dram: 1.660
QPI/PCI PLL: 1.290
Ive been trying
