Its really annoying as well, today i was cleaning it and giving it a wax and i found so many of these faded dark area's which you can see when you look closely. Looks fine from far away though.
Get some Meguiars Scratch X and Meguiars round aplicator pads to remove any etching marks. Ok, it may not completely remove it if it is really bad, but with a little patience and passion, you could make a nice job of it.
It depends how big the area is, but id say maybe a little bit of t-cut and then polish until your arm goes numb.
Ideally you need to get it off as soon as you notice it. Its a pain but prevention is better than the cure and all that. Most of the time I just chuck a jug of water over it on my way out in the morning.
