I will start off this thread with a few pics of my 1st water cooled build:
Lessons I learned:
- Using a case not designed for a watercooling build is not a great idea. My Antec P120 was a great case and has served me well for many years now, but I had to hack the hell out of it to make get all the watercooling gear mounted. Most of it ended up external to the case which was pretty fugly. It also meant running a bulk head port through one of the side panels which meant you couldn't remove this panel without draining the system, severely limiting access to the case.
- Anti kink coils do absolutely sod all. At least with the decent tubing I was using (Primoflex). This stuff is not going to kink.
- A flow meter would be nice, towards the end of this builds life I suspected the pump was failing. However there was no way to really see this short of pulling everything to bits.
After suffering an unexplained system fail (I suspect something terminal happened to the motherboard) it was time to build anew, and hopefully do it better this time
Lessons I learned:
