Hi looking for some better fans for my case to try and cool down my gpu that is making abit of noise while gaming, the standard bit fenix fans are rubbish and hardly push any air out.
So what I want to do is achieve better airflow in my case with new fans at the front and at the top of the case. Could anybody recommend any fans to get for the bit fenix case and would I need to have a mesh front to achieve a better air flow ?
abit stuck for room on the top of the case so that would after be a 120mm but can get a big one at the front as I have plenty of room
if you could list the product below that would be a big help thanks
that's my case http://www.overclockers.co.uk/showproduct.php?prodid=CA-144-BX&groupid=2362&catid=1850
