Bit lost, GTX 1060 variants.
16 Aug 2017
Hi,
Buying a PC from this site today or tomorrow,
Here is the build
Case Phanteks P400S Noise Dampened Gaming Case with Full Side Window - Black/Red (Other Cases Optional)
Power Supply 650W 80+ Gold Rated PSU
CPU AMD Ryzen 5 "Zen" 1600 Six Core (twelve thread) CPU overclocked to 3.8GHz
Motherboard Asus Prime B350-Plus (Socket AM4) ATX Motherboard
Cooler Cooler Master Hyper 212 Evo CPU Cooler
Memory Up to 32GB DDR4 2400MHz Dual Channel Kit
Primary Hard Drive Your Choice of Intel/Samsung Solid State or Seagate Hard Drive
Secondary Hard Drive Your Choice Seagate Hard Drive
Graphics Nvidia Geforce GTX 1050 2GB Graphics Card (Other Cards Optional)
Audio 7.1 High Definition Audio (Dedicated Sound Card Optional)
Optical Drive 24x DVD-RW (Optional)
Operating System Windows 10 64 Bit
Cost £1349.94
The question is, the only 1060 I can choose when customising is the one above however I see they have a Zotac variant in stock as well as many others. The price varies, some a little and some a bit more, but what is the real difference. I don;t mind paying an extra £10-£20 if it's worth it to get a better GFX card so which should I get??? They are al;l GTX 1060s with 6144. Overclockers Uk will build it so I will ask them to sub one model for another.
Here is the list on the site....https://www.overclockers.co.uk/search/index/sSearch/geforce+1060+6144/sPerPage/12/sPage/1
Anyone able to provide and insight and advice?
Also, if anyone spots anything glaringly problematic or easily improved in the build recommendations are more than welcome.
Thanks in advance.
If it were me I'd buy the cheapest 6gb 1060 with the longest warranty. They're all built to a reference design anyway with the only differences usually being the cooler and warranty length. The cards you have an option of picking from are all overpriced in my opinion.
I have the same question regarding the 1070
I have picked for my next build which is currently in progress and this is currently in my parts list.
EVGA GTX 1070 8GB SC GAMING ATX 3.0 £439.99
I picked this purely for aesthetics reasons only as i liked the EVGA logo on the outside of the card.
Yes, it is a bit of a tease sitting there with no stock announcements.
Yes, they are a bit thirsty - 500W would be pushing the limits - especially if you had an AIO and were clocking...
Wont be clocking, looking at the reviews its punch for punch with the 1070..
I meant your CPU (guessing Ryzen?) - but with the Vega 56 you actually under-volt them and then aim for a clock - they still power spike (from reading forum banter).
And yes, you won't be disappointed with the GTX 1070.
