I have an Intel Dual Core CPU with a stock CPU fan and a standard (nothing special) fan for the case.
The noise level this Computer gives off can be very high, I am assuming the biggest cause is the Intel CPU fan and then the Case fan.
I also have a 7600GS Nvidia card that misses parts of graphics in games, I am assuming again due to the fans and not keeping the PC at low temp.
I got this from the speedfan software, this is what it says:
GPU 63C
System 40C
CPU 53C
AUX 46C
HD0 31C
CORE 67C
Ambient 0C
The big fire picture next to the CPU GPU and CORE means my PC is on fire?!
So far I have decided on these for lower temperature and no noise (or as close as I can get):
Freezer 7 Pro
http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR&groupid=701&catid=57&subcat=821
Cooling Fan
http://www.overclockers.co.uk/showproduct.php?prodid=FG-003-AR&groupid=701&catid=57&subcat=4
Any help would be great, thank you!
GPU 63C
System 40C
CPU 53C
AUX 46C
HD0 31C
CORE 67C
Ambient 0C
Freezer 7 Pro
Cooling Fan
