- 24 Nov 2002
- 38.744281°N 104.846806°W
I have some data in the following format:
I would like to have this formatted as:
i.e. strip away the first colum (QW_xxxxxx.x), then put every remaining column (containg the 7 digit number) - regardless of row onto a new line, prefixed with AN: )
I have been using excel to at least to the initial bits but it has fallen down and form some reason I loose the "000"s when I export???
Therefore a php solution would be fantastic.... however, I'm stumped...
Presumuably I need to read the text file as an array, implode it... no no I have no idea...
Help me please!
edit - some rows will be blank, e.g.
so the script must be able to ignore blank rows (as when first column is removed, row will be blank)
Code:
QW_004125.3 0006457 0003674 0008219 0005737 0005515 0008152 0016265 0005488 0005739 0008150 0005623 0043067 0044260 0006916 0044424 0005575 0050789 0044444 0050791 0017076 0043118 0048523 0043069 0050794 0051244 0009986 0019538 0051243 0005524 0051082 0042981 0043229 0043226 0006915 0044237 0044464 0043227 0005622 0043231 0009987 0007582 0000166 0043066 0043170 0044267 0012501 0048519 0030554 0050875 0044238
QW_001311.3 0030234 0042802 0005956 0003674 0005515 0007165 0005488 0008150 0008605 0019207 0005623 0044424 0005575 0016055 0003824 0019887 0007166 0044464 0005622 0016772 0009987 0007154 0016740 0016301 0043234
QW_001605.1 0005200 0003674 0005515 0044422 0005488 0015629 0005623 0044424 0005575 0017076 0005198 0043232 0044430 0005884 0005524 0005856 0043229 0043226 0044464 0005622 0043228 0044446 0000166 0030554
..etc....
Code:
AN:0006457
AN:0003674
AN:0008219
AN:0005737
..etc....
Help me please!
Code:
QW_004125.9 blahhhhh
QW_004125.3
QW_004125.2 blahhhhh
... etc....
