Bit of a challenge - Vapo + INX-720
15 Aug 2003
I’ve looked far and wide but have failed miserably so now I have to you with a challenge to find a chassis that I could not.
I’m looking for a case in black or silver with a footprint of 210x490mm that does not have a strange system for media storage underneath the main cabinet so that a Vapochill (Scroll down to the bottom) unit can be used. That bit is easy; Lan-li do a reasonable selection of cases for this.
The part of this that makes it insanely hard is that the case must also have at least 2 inches (51mm) of space above the power supply in the rear so that an INX-720 system can also be used. I’m aware that I could use an Exos-2 instead of an INX-720 but put simply, it doesn’t look nearly as good.
If you cannot find one either, could you please recommend a custom case builder that I could commission (Yes im that desperate)? Or does anyone else have any ideas? Cheers.
-Will
Yewen said:
Would the pc70 fit the bill?
Or how about a Cheiftec case, they have the internals that may be able to suit.
The internals of both fit well. Unfortunately all the Chieftec’s I had a look at were too thin at a 205mm width instead of a 210mm which would look nasty.
However the PC-70 was a very good suggestion I hadn’t noticed it before, the internals fit the spec and its width is 210 but its Depth is 588 a full 98mm more than I want but I –could- fashion a box for the rear of the unit but that would rise the whole question of the join between the rear of the Vapochill and the box. But I also could make an entirely new Vapchill casing (Would need to get my hands on a unit to see how much of a job that would be, im guessing it isnt easy). Good ideas, thanks for the help.
Anyone else have anything?
-Will
Yes indeed you can but unfortunately they are of 490 depth rather than 588 depth.
According the the vapochill site they fit the;
PC-60, PC-61, PC-65, PC-7, PC-12, PC-37, PC-82, PC-601, PC-0700,PC-0716a, PC-0716s, PC-6077, PC-6085A.
Unfortunately none of these have a 51mm clearance above the psu and the pc-70 isn’t in that list :(
There are plenty of pics of people with PC70's and Vapos.
Add me to msn and I will give you a few pics.
Email in trust aswell. Or you can go through my sig!
So many options!
