Bit of a DIY question
17 Jan 2011
London
I've been using a wireless card for years now and I'm finally getting tired of it. I've ordered 30m of cat5e cable and I plan to hook up to my router which is down in the kitchen.
The route I plan to take is as follows:
I have the "box" room on the first floor at the front of the house. Router is downstairs in the kitchen extension at the back of the house.
I plan to run the cable up into my loft, through the loft and then down the back wall of the house which I'll tack down with those cable pins and then drill a hole through the wall into the extension and hook myself up.
The problem bit is this. I want to run the cable up the wall in my room with as little damage as possible so I plan on buying some plastic cable trunking and running it up to the ceiling. However, there is coving separating the ceiling and the wall. What would be the best, neatest and tidiest way of running it into the loft without obliterating the coving?
One idea is to drill as small a hole as possible through the ceiling and then try the make the cable run in the corner of the coving neatly. But the chances are it'll just sag and look silly. Or should I just drill neatly through the coving as low down as possible and try and run the cable up the wall still?
I think the second is the better option personally as I could then use a junior hack saw on the truning to make it cover any damage around the edge of the hole in the coving.
But I just figured I'd get GD's opinion first :)
Simple, drill a hole behind the coving, it's what I've just done rewiring our bedroom.
I've got a picture were you should just be able to make out what I've done.
If you look closely I was a bit clumsy and removed about a cm of coving but with a bit of filler and now painted you can't tell :)
Or you could get some of these....
http://www.devolo.co.uk/consumer/77..._starter-kit_product-presentation_1.html?l=en
Uses the electrical cable in your house to act as a cat5e cable. 'Ive used them for years trouble free. I get 600mbps and 20ms - can't tell the difference between that and a cable.
Just plug into socket, plug your cable into that and away you go. You can add extra outlets for other PCs in other rooms as you go too.
Yeah I'm glad you've confirmed that for me. Cheers! Will just have to get to grips with a careful bit of plastic sawing again!
there are cheaper homeplugs around.
£40 should get you decent set,ill be doing this soon as i dont want to rip apart my house (solid walls).
Your putting the light switch behind the door :confused:
Would have been more practical on the other side!
Something to also think about when doing this is to give any bends / right angles in the cable run about 3 inches. That way you should be able to run it at gigabit speed down the line if you wish.
As for the coving, I've always replaced the section and cut a small channel in it before sticking it back up, but that's not always practical.
Ah right. Cheers for the tip mate. Not sure how this gigabit speed works though. Is that dependent on your net connection or your cable connection? I know you get gigabit network cards for PC's, but don't really understand how they work in relation to the whole network.
If you turn the door round however, it's now on the correct side :)
Makes more sense having it open to reveal more of the room anyway. Looks good though dude! Just missing your light switch!
For the gigabit speeds you'll need a network switch or router that has gigabit ports and a gigabit card in the pc. Most new motherboards come with gigabit LAN cards these days. You'll only ever get as good as your Internet provider supplies you to the outside world but if you ever connect other devices and want to share files you'll get much better throughput and faster transfer speeds.
How boring.
They also used to put light fittings close to the window so not to cast a shadow of you changing out to all.... Not that it actually does lol. Moved many light fittings to the centre of the room.
I would have thought doors opening into rooms makes more sense because you're far more likely to open it into someone in a corridor than vice versa :p
They also used to but light fittings close to the window so not to cast a shadow of you changing out to all.... Not that it actually does lol. Moved many light fittings to the centre of the room.
That's how the light fitting was in my bedroom in my second year at uni. Bugged the hell out of me..
Oh gosh. The fact that my light is on the 'wrong side' has been bugging me for ages. I just didn't think to rehang it. That'll give me something to do tomorrow!
