Right, I'll start from the beginning.
Motherboard is a Gigabyte 7VTX. 768mb RAM, 10gb IBM IDE drive, Pioner A06 slot DVD drive, Nvidia (?) card, network (3Com?).
I have a Compaq Smart Array 3200, connected to 2x 9.1gb IBM SCSI drives. This is installed in the bottom-most PCI slot.
Had a bit of a chew on getting into the case - five minutes of dremelling sorted that out.
Got the card installed, setup a RAID 0 array - so far, so good. Did a quick format, and the thing just hangs on, forcing me to stab the reset button on the case.
Thought it might be a firmware issue with the card, so downloaded it, ran the software...bluescreens on me!
I would be VERY grateful of any advice/help anybody has to offer. Even any suggestions you think I might have overlooked (and probably have).
So I thought, right could well be a driver issue. Downloaded HP ProLiant Drive Array Driver for Windows 2000/Server 2003, updated drivers and rebooted. Still the same, when performing a quick format!STOP: 0x000000D1 (OxF594063E, 0x00000000, 0xF5947D05)
