I built a PC for a friend's father-in-law a couple of years back, and installed Windows 7 Home Premium (boxed version). The PC has been fine, and now all of a sudden is reporting that Windows is not Genuine etc.
Activation status shows as 'Not Available' and I struggle to get it to access sites such as Microsoft Genuine and so on - ironically, things like Google, BBC and so on all seem to work fine, but anything that might be 'useful' does not.
It seems to have Norton IS installed, but does not run....I used the Norton disc to get to web-based tools, which cleared a few things up, and also booted from the DVD to run a full scan...which brought up no issues.
Apparently, these problems have started since trying to install iTunes etc., as he has been gifted some sort of iPod. I have struggled, but finally managed to remove all Apple bits and pieces, just in case......
System Restore appears to be turned off - the last restore points are 6 months old, and apparently not on installed drive(s). No hardware has been changed, though.
I have run the MGADiag tool, which has basically told me that the Product Key is invalid and an error code (which I can't recall)....have tried a CMD as Admin and run all applicable variants of slmgr.vbs to try and remove duff product key info, re-enter product key and so on....but can never get the Product Key to 'stick' for activation. I *know* that this Windows licence is genuine, as I purchased it and installed it for him when building the PC.
So.......this is either a nastily corrupted Windows install = format and reinstall....or is virus/malware related ?.....or there is something wrong with the Product Key, which makes no sense.
Help ? Please.....
Help ? Please.....
